omega
Strange 205 Sight In Rotherham
omega
today at about 1130 i saw a white 205gti in rotherham
what was strange was the wheels ,on the front he had speedlines and the rear had pepperpots
so 15 on the front and 14 on the rear
the car looked tidy
i suppose he done it either for gearing or brake upgrade but ive not seen this before
anybody on here own it?
DrSarty
Or lack of 2 more Speedlines....or pepperpots even. :mellow:
it had ford wheels on?!
omega
:wacko: yeah i know but
1 you know what i mean
and
2 i dont what else they called :mellow:
please enlighten me oh great one
There are a couple of white cars that kick about, I've not seen one running odd wheels though.
richsmells
So what?
:mellow:
Rippthrough
It's Rotherham, someone probably nicked the rear pair of speedlines whilst he was stood at traffic lights.
DrSarty
Or swapped the 'pepperpots' on the front for Speedlines.....at the lights. :ph34r:
omega
So what?
:ph34r:
so why?
Rippthrough
The only reason it takes the Virgin boys so long at pitstops is because the local lads are blowing over the old wheels to sell on ebay.
lyncho23
ive done this before just because my front tyres were bald and i couldnt afford new ones so i put 2 spare 1.6 wheels i had with good tyres on the front
Daviewonder
I done this a while back due to a bald tyre, there needing to be matching tyre size on a axle, and the fact 14" smr wheels don't fit over 1.9 brakes :P
Edited by Daviewonder
Rich_p
14" smr wheels don't fit over 1.9 brakes :)
Really?
Do speedlines?
Best I check the pepperpots I have in my garden, pretty pointless them being there if they won't fit the car!
DrSarty
14" 1.6 wheels did not fit over the brakes on my phase I 1.9. Well they did, but they rubbed badly.
rubyna
Really?
Do speedlines?
The Speedlines will obviousley as they were origionaly fitted to the 1.9....
Phil H
I thought it was an MOT fail to have a smaller tyre on the rear...or is that the width?
SurGie
Yes, both the front and rear have to be the same size, ie 15 inch for example.
But the two tires at the front have to be the same, ie 50, even if the rear two are slightly different in height of tire. Mine passed with the two front being different to the rears.
Edited by SurGie
Rippthrough
Seems strange, are you certain that's the case? As there's a few cars that were released with 18" rears and 17" fronts for example...
Daviewonder
No, you can have different size wheels front and back. you just have to have matching wheels/tyres per axle.
jeremy
I've also done this to try and eliminate a vibration problem ie an unbalanced wheel, and due to low rubber.
Rich_p
I was talking about pepperpots made by speedline as opposed to pepperpots made by smr!
omega
carefull rich you will upset baz calling them pepperpots :lol::D:D
[see earlier post in this thread]
Edited by omega
shalmaneser
Just what I was going to say, half of the new mercs have bigger tyres on the back than on the front. I assume they have to match across the axle.
I've seem lots of fords on 205 wheels actually, a guy near me used to have a capri on 1.9s, and in Brighton I've seen a fiesta on 1.6 wheels.
Both looked quite good I thought.
Obviously would look better with the rest of the car swapped for 205 bit tho!
omega
yes they have to match across the axle
merc smart cars also have diffrent size tyres front and rear and no spare which is great for me as i sell/install a lot of my puncture safe on these.
