burr_2000
Driveshaft Question
burr_2000
I know 205 and 106 driveshafts are different lengths but are the hub ends the same? there is a endless supply of 106/206s in local scrappy and i was think bout just swapping ends. i swapped the gearbox end of my 205 shaft to 106 rallye end when i fitted the 106 rallye box and wondering if its possible for other end as 205s become rarer.
only on 1.9 shafts you can swap outer ends, and these are larger than 106 shafts.
burr_2000
ah ok. does anyone know where to get reasonably priced uprated/tougher driveshafts?
giveitsomebar
are you using 1.9 hubs or 1.6?
burr_2000
1.6, thanks to gary muir i have sourced a company that does uprated shafts for the MA pug 205 with the 6 ball zapella rather than the common 3 ball. ;)
