pugpete1108
Oil T Piece Problem.
pugpete1108
while i had the inlet off today i thought i would tackle the oil leak i have dow the front of the block.
first i thought it was the oil/water cooler plate but on closer inspection i found oil leaking from one of the three joins on the t piece i brought to run oil both oil pressure sensors.
i cant pinpoint what one it is but i think i can rule out the one that connects the tpiece to the block as this has a metal washer with a rubber centre (came with it from demon tweeks)
i will get a small one for the mushroom sensor but the problem lies with the other sensor in the pic on the end. this is as far as it screws into the t piece? i was using two copper washers in the gap but i am guessing this is/was no good. the gap looks to be about 4mm.
how the heel do i get round this? my first thought was to cut few threads off the sensor but i'm not sure if this will affect its function? other than that i guess a 5mm copper washer if there is such a thing?
what a pain in the arse having to go over these things again and have the engine in bits again grrr :)
PTFE tape on the threads? If it's just a weep then that'll probably be enough to sort it.
pugpete1108
if this is what is causing the leak then its a good old weep :)
i get a small puddle (15cm across ish) under the car overnight
i just ahd an idea thought, i rubber washer actually down in the hole between the end of the sensor and the end of the t piece + some ptfe and two copper washers. if that dont fix it..........
Edited by pugpete1108
just some PTFE tape should suffice, you can see from the gap that they aren't intended to use washers.
pugpete1108
cool 2 problems solved in half hour.
what a helpfull forum :D
Paul_13
I used a few copper washers didn't cause a leak, but I used a different design as it was smaller.
PTFE/ One Wrap will do the trick. One Wrap is thicker.
Or even some Loctite55 if any of your mates are pipefitters/plumbers?
