JamieTonks
Somone To Set My Suspension And Neg Camber Up
JamieTonks
Hi Guys
do you know anyone in the midlands area who can install my new front coilovers, excentric top mounts, 309 arms and 309 shafts and set it all up with a bit of camber?
Im not sure how easy or hard it is to get it all set up correctly
Thanks Jamie
All Praise The GTI
hi mate forwarded those pics did you get them?
those are all pretty simple parts to fitt and you can set the topmounts up roughly then go get it set properly at a garage :D
JamieTonks
can any garage do them?
and yes i got the pics mate will be in touch
Edited by JamieTonks
All Praise The GTI
not all i doubt but im sure most places that do tracking and allighment could
cool :D
Contact Ed at EJM Preparation on the industrial estate in Alcester. He knows his way around a 205 and can do as you need and also set the corner weights.
Henry Yorke
Itherwise I am sure someone at ABMotorsport would be able to point you in the right direction.
JamieTonks
Great they are like 10 mins away from me :D
He is an old mate of mine now running his own motorsport prep business, has rallied 205's and 309's. If you search the net he has a website with contact phone numbers on it. Mention me when you ring up.
JamieTonks
Thanks :D :D
brumster
Jamie, give Andy at AB Motorsport a call. He can probably do this himself but there is also a guy two units away from him with all the right setup kit, he's ex-ralliart and does proper chassis setup. He set up my rally car on it's Reigers and the transformation after having it done properly is well worth the money. Andy tends to do the ground work of fitting all the bits, then the chap round the corner can set it all up properly for you.
edit : Actually Andy is away on event at the moment, so might need to give it a week... :D
Edited by brumster
