sam-barker
306 Hdi Calipers
sam-barker
I have in my garage a pair of lucas calipers off a peugeot 306 hdi (2000 W)
just wondering if they'd go on my XS?
Cheers!
swordfish210
Yep, you would need the HDi 266mm discs as well, and some slightly longer hoses if they're standard.
You might benefit from at least a GTI sized master cylinder imo.
The hdi has 54mm piston calipers where the 205 GTI (& XS afaik) has 48mm pistons so your pedal will be longer but tbh an XS will have plenty good enough brakes with standard sized GTI vented discs & calipers (which will bolt straight on).
Graham.
