wardy18 33 1 Cars Posted May 4, 2010 So now starting to look at all the old parts to re-vamp them for the new shell, my passenger drive shaft cv boot crapped itself when the front came round and hit the wall after the rear impact (no idea how) Anyway please see the pic of the shaft in its current state, i need to know if it can still be used as a couple of parts have broken but from what i can see these parts are NOT vital. There is a 3 point bracket which would clip onto the shaft holding in the cv joint (see green circles), unfortunately the arms have snapped and so this cannot be used anymore. Also there is a small spring which if you follow the red lines sits in the middle of the cv joint and the dome topped item sits on the spring. However the sping has snapped Hard to describe but from i can see the fact that the shaft is fitted between hub and gearbox and held together with the cv boot, nothing can fall apart?!? Opinions please as im sure this has happened to others over the years Share this post Link to post Share on other sites
welshpug 1,645 Posted May 4, 2010 as far as I know 1.6 driveshafts are not meant to be dismantled, so if they have come apart tghere may well be some damage. Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted May 4, 2010 1.6?? These are (or should be) 309 GTi shafts Its just the fact that the 3 little arms have snapped off that bracket and so this bracket will no longer clip on where the green circles show. I think this and the spring are there purely to reduce wear by putting a little tension holding the shaft onto the cv joint. Im racing for seconds at a time not doing 100 mile a day on a motorway. Only my opinion but hopefully previous experience can set me on my way Share this post Link to post Share on other sites
welshpug 1,645 Posted May 4, 2010 the outer CV on 1.9 205 and 309 shafts are the same and have more balls, and can be knocked off the shaft without being dismantled, that almost definitely looks to be a 1.6 or base model shaft to me count how many splines you have on the outer CV. Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted May 4, 2010 when you say outer cv, do you mean the end which goes through the hub?! Im running 309 hubs Ill have a count Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted May 4, 2010 This end bracket that has snapped doesnt look like fresh snaps either and this bracket could definitely be un clipped to take cv apart Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted May 5, 2010 Outer Splines = 25 Inner Splines (At the Diff) = 24 Are these 309 shafts?! Ive always bought 309 GTi shafts and they have worked in my hubs Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted May 7, 2010 Definitive Answer required - What is the difference between running 309 GTi Shafts and std 205 shafts?! Also between 309 and 205 Hubs?! Ie. Wider track, more splines, longer shaft Regards Simon Share this post Link to post Share on other sites
welshpug 1,645 Posted May 7, 2010 simply wider track due to the 10mm longer wishbones each side. and a longer centre part of the driveshaft (by 10mm each side again) Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted May 7, 2010 Great thanks, ill save future heart ache and replace thatt shaft shown above, its looks like it would still work to me but do i wanna risk it....no! Share this post Link to post Share on other sites
James_R 3 Posted May 7, 2010 As said that looks like a 1.6 shaft, which means you'll have base model or 1.6Gti hubs on there, with the smaller bearings. Pop a pic of the hub up Share this post Link to post Share on other sites
Tom Fenton 1,536 Posted May 7, 2010 Another way to tell is to measure the outer size of the thread where the nut goes. 20mm is 1600. 24mm is 1900. Looks like 1600 stuff to me as others have said. Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted May 7, 2010 ill measure tomorrow for sure! I do know that front bearing measurements are: Outer dia 82mm Inner dia 42mm Depth or Height 36mm These are the same for 309 and 205 1.9gti, didn't look at 1.6 details Simon Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted May 8, 2010 just measured outer threads on each shaft and they both 24mm These must be 309 gti shafts then yeh? Share this post Link to post Share on other sites
welshpug 1,645 Posted May 9, 2010 they might be, I remember Miles commented that some manufacturers had made 1.9/309 length and splined shafts with 1.6 type joints. Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted May 9, 2010 these are the ones I got with the old shell so never knew any better In need of a new set of 309 1:9 gti shafts if anyone has a set? Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted May 11, 2010 Anyone know if a 405 mi16 driveshaft has the extra 10mm length on them as with 309 units? Share this post Link to post Share on other sites
welshpug 1,645 Posted May 12, 2010 405 (and most 306's) 600/886 compressed length, 205 1.6/1.9 is 567/840 left/right respectively. Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted May 12, 2010 i found a website yesterday which stated every model of peugeot driveshaft lengths, very useful as 405 units are, as you say, even longer than 309 so if you can get a set fo these on adjustable wishbones you can get a veru wide track and easy camber adjust with no worry of popping cv joints through stretching them but are these 405 ones as strong?! they come from the 1.9 and 2.0 Mi16 so i'd say so in my opinion!! ill link up the site later as its very useful Share this post Link to post Share on other sites
welshpug 1,645 Posted May 12, 2010 I wouldnt say they'd be any stronger, mine were identical to 1.9 205 abs items, bar being longer Share this post Link to post Share on other sites
