rescue dude
Strange Noise From Refurbed Beam.
rescue dude
As above, i'm getting a loud metallic ping from the near side of my beam. Only seems to be on sharp right hand turns, usually at slow speed and at compression.
The beam was fitted and refurbed by a mate so no problem getting it sorted but I have to say i'm a bit baffled by it.
Other than the "ping" it feels fine and has certainly improved the handling.
Any ideas?
Paul_13
Loose torsion bar? ARB not tight?
swordfish210
Loose damper bolt would be my guess. The bottom ones need to be torqued up to 118nm IIRC
j_turnell
I would guess it to be the arb end plates, check they are a nice tight fit on the end of the arb. Best off removing it, 10 min job, and go for a quick drive and see if the noise is still there.
rescue dude
When I get a chance i'll check it all out.
Thanks for the ideas.
tri_longer
Sounds like the ARB, i've had a similar thing before.
rescue dude
I take it that it just needs tightening up?
If I do a spanner check on the beam does it need to be up in the air or under load like wishbones? Or doesn't it matter?
Edited by rescue dude
andyjstone
I just found one of my bottom damper bolts was loose, but that was causing a knocking, not a ping!
rescue dude
Mine sounds like someone is hitting it with a hammer.
A sort of dull ping.
Not had chance to check it out yet. Hopefully tomorrow.
tri_longer
No idea to be honest, i haven't fixed mine yet. So hopefully someone can answer for the both of us.
As it happens I had to loosen it off on Saturday and forgot to do it up until it was back on the deck with a wheel on so I will see if it has made a difference on Thursday when I go to the meet.
rescue dude
I know know what it isn't.
Torqued up the rear shocker and the bracket that holds the brake cable but it still pings.
I'm pretty certain now that it's the ARB as it's definitely something thats under tension.
I'll have another look tomorrow. ;)
