backroadpug
1.6 Gti Brakes And Hubs
backroadpug
hi i have a set of front hubs discs and calipers of my 1.6 gti as i have just fitted 1.9 set up
was wondering if the 1.6 hubs and calipers would fit my RALLYE and would i have to use the rallye flange for the drive shaft if they do?
cheers
Edited by backroadpug
1.6 GTI hubs & calipers should fit straight onto your Rallye without changing anything else.
Graham.
backroadpug
cheers graham ill give it a go this weekend
Yup, I did exactly this on my old 205 XS to give it wider front track ;)
backroadpug
and the rallye shafts fit the 1.6 gti splines? just a straight swap
Yup - keep the original driveshafts, and just bolt on the complete 1.6 hub/carrier assembly, disks, and calipers (in my case I used 1.9 calipers, but 1.6 ones will work fine)
