Ant
Removing Bolts From The Gearbox - Any Issues ?
Ant
Hi Folks,
Im restoring my CTi from the ground up – Complete respray etc.
The Mi16 lump is currently in the garage and i’m having every visible nut, bolt and bracket anodized. I also plan on painting the block and head.
I would also like to do the gearbox.
Couple of quick questions though. I want to lay the box flat on a table, ie the flywheel side of the box face down. Will this do any damage to the box, being layed face down for a week or so ?
I would also like to get all the exterior bolts on the box anodized. I will replace a few with “spare” bolts to ensure it stays held together. However are there any “no no” bolts that i shouldn’t remove that could cause potential gearbox probs in the future ?
mickie
http://www.rallyparts.co.uk/cwp_change/
this may give you an idea
i dont think you'll have a problem laying it flat on the table.. you can take the end cover off without problems..
im not sure it would be a good idea to pull the bell housing bolts out as you may brake the seal, pm miles, on here for details
Edited by mickie
Ant
Cheers for them links.
Thinking the same about the bell housing..
anyone confirm if i can remove the bolts ?
