Simes
Toad Ai606 Programming - Help!
Simes
Hi,
1/Alarm installed
2/All works nicely
3/Decide to get the chirp to sound on lock and unlock, works first time
4/Chirp is annoying
5/Want to turn chirp off
6/I follow the instructions......into programming mode
7/Am now in the switch setting for all functions on switch one.
8Go to to disable the chirp 1-5
9/LED tells me that the chirp is off.
10/This is not true as it continues to chirp, allied to that it chirps when the doors are physically opened.
11/Try to reset all switches back to default - this doesn't work
12/Repeat the above many times
13/No joy...shout a bit.
Has anyone else had this?
Any form of solution?
davev
not much help i know but on mine if i dont want the alarm to chirp when arming or disarming all i have to do is press the button below the locking one once then what ever one i want to activate. this will then open or lock the doors silently.(bar the sound of the nackered motors jumping around like crazy :lol: )
Simes
not much help i know but on mine if i dont want the alarm to chirp when arming or disarming all i have to do is press the button below the locking one once then what ever one i want to activate. this will then open or lock the doors silently.(bar the sound of the nackered motors jumping around like crazy :) )
Thanks, but unfortunately that would not fix the chirp happening everytime you physically shut the door.
I've fixed it now by simply disabling all the options on switch one, tomorrow I will reintroduce them until I find the offender. Basically the alarm is not doing what the guide expects it to do!
