Tommer
Selecting Reverse Gear...
Tommer
Hi all,
just thought it was worth checking whilst I still have 2 gear boxes to choose from...
new car when selecting reverse, the gear crunches, all forward gears are find, just reverse. could this be something as simple as clutch adjustment, clutch on its way out, or gearbox stuff, or syncros need looking at?
the gear box on the old car never crunched (if i recall correctly) so would it be worth just swapping them? any thoughts appreciated
they are both BE3 (i think), both cars 1.9 gti 8v
cheers
Paul_13
Reverse doesn't have syncro mate. Might be your clutch not fully disengaging.
maxi
Little tip for stopping reverse crunching. When stationary and wanting to select reverse, if you are running a BE3 box, slip it into 5th then straight back into reverse. Will slide in like a well lubed female everytime.
Maxi
Daviewonder
I think mine used to do this when my idle was too high iirc :)
Tommer
Thanks for the info / tips. will try and see what happens :)
