309andy
How Do I Tell If My Gearbox Is For A 1.6 Or A 1.9?
309andy
im hopefully going to be converting my car back to a 1.6 but i wanted to make sure if ive still got a 1.6 gearbox,
so i was wondering, how do i tell the difference? eg is there a code anywhere?
thanks in advance to anyone who can help
No code etc, but if you remove the diff cover the amount of teeth on the CW&P is written. And you should be able to roughly judge it from speeds at different RPM etc. In fifth gear, 1.9 is roughly 80mph at 4k, and 1.6 is at 5k at 80. (iirc!)
Edited by Baz
j_turnell
59 / 16 = 3,6875 (1.9)
65 / 16 = 4,0625 (1.6)
I think these figures are correct.
BusEngineer
What about Mi box then?
Ive got two gearboxes sat in my garage that i paid very little for, and both were sold as suspected Mi boxes
Are there any ways to tell? Or if i have to strip them what am i looking for on the diff?
brumster
The tooth combinations are normally stamped on the crownwheel on the flat section, arent they? "65x16" etc...
Yes, they should be.
65 x 16 is the 1.6 / 4.063 fd as mentioned above, the Mi16 4.43 FD should be stamped 62 x 14.
