quagmire
Interior Light Wiring
quagmire
My interior light doesnt work when I open the door so today I decided to investigate only to find that the door switches have been disconnected. The only wire I can find that can reach either side are green earth wires but the switch is 2 pin? Any ideas on how these are supposed to be wired up?
Edited by quagmire
j_turnell
It should just be a single wire, if you remove the plastic kick plates either side and find the loom that goes into the doors and there should be a single 1 pin connector off that.
quagmire
They're the ones I have connected up but still no light.
GLPoomobile
They are earth points. The light will be fed by a live, and then is earthed via the green wires connected to the door switches. When the door is closed, the contact is open, so no earth, no current flows, and no light. When you open the door the contact closes and the circuit earths.
I'd place my money on it being badly corroded door switches.
quagmire
The pins on the door switches seem to ok or are you saying they a rotten on the inside?
ade 4wd
The door switches are prone to corrosion. Dissconnect the switch and earth the wire at a known good earth point and the interior light should come on. Does the interior light come when you switch it on manually?
quagmire
problem fixed, thanks for the help.
