Silky
10 Point Omp Cage Fitment
Silky
Myself and Alex (Boombang) are going to start fitting my 10pt OMP cage into my GTI this Sunday
I have already sourced plenty of steel from a friend to make the box sections to mount the cage feet on.
What I need to know from someone who has fitted one of these cages before is
How many bolts will I need
What length should I use
What grade of steel
I was going to get 50 nuts+bolts 12.9 Grade, would this be sufficient or too much ? (quantity + grade)
What length do I need and do they need to have a shank on them at all ?
Michael
Jrod
What grade of steel
Michael
14 bolts for the feet, 2 seatbelt bolts for the B pillars and some smallers bolts for infront of the windscreen. We used 10.9 so 12.9 should be plenty.
I wouldnt get a shank as the foot it goes through is fairly thin, length wise I can't remember but it can be fairly long as it will just sit inside the box section, just makes it a pain to remove if you have to.
Edited by Jrod
Silky
Not as many needed as I thought then, my friend works next to a fastneners so I can ask him to get them for me.
So going by that Jrod I could do with
Quantity 30
M10 x 40mm length
12.9 Grade
joe1joe
acording to the msa you can use m8 8.8 minimum,
not sure if m10 slightly big for the original holes?
surely m8 with a higher grade than minimum
so where do the plates above the windscreen bolt to, or do you have to weld plates on?
EdCherry
All my bolts for my SD cage are 12.9 M10x30mm. Cant remember how many I needed but 36 is in my head for some reason.
Silky
Any washers need or just the bolts and nyloc nuts ?
EdCherry
Yer you need washers but cant remember how many ive got all that as stock items.
Silky
I'll get a pack of 100 then
pugpete1108
you still want these harness plates silky?
Silky
B****X
Totally forgot you had them Pete, ordered my set from Rallye Design literally two hours ago.....sorry mate
hothatch
8 x 25 is plenty for the feet and m10s for the diagonal in the back
Oh yeah I used 10.9 black allen key button head bolts m8 x 25, they looked the part .
Edited by hothatch
pugpete1108
B****X
ah no worries mate, someone,sometime will want some no doubt. i should have reminded you earlier.
