JamieTonks
Fast Road / Track Set Up Advice
JamieTonks
Hi Guys
can you recomed me a good suspension set to put on my 1989 gti. Its suspension is curently standard however i want to change it to something with would suit the track better.
The car currently runs a gti6 engine however i do plan to run a fair bit more than the standard engine :)
Previous on my old 205 I used a set of excentric top mounts, gaz coilovers, compbrake lower arms and 309 drive shafts on the front of the car.
Im tempted to do the same again however is their a more cost efective way or simply a better set up which someone could suggest?
Thanks Jamie
Good to see you back with a GTi! :)
I guess the main question would be what you're actually doing with it?
I wouldn't bother with the cheaper Gaz(or any other cheapies for that matter) coilovers, and go for some Koni/Bilsteins at similar pricing, with Eibach springs.
JamieTonks
its probably going to end up been superccharged and only been used on the track or having fun in on a sunny day etc.
would you only change the struts and springs or can you recomend anything else. also where is the cheapest place to get bilstiens
