Andrwn8304
Front Hubs And Hub Carriers
Andrwn8304
A right pain for you's to work out lol
I've had a slight knock on the suspension for about year and I think I've gradually tracked down the culprit which might be the N/S Hub or Carrier. After checking and replacing Worn parts like Drop Links, Anti Roll Bar Bushes the knock still persists. As both Driveshafts were replaced last year due to wear in the C.V. Joints I've ruled that out.
Is there any difference between Phase 1, 1.5 or 2 Hubs and Carriers orare they standard throughout the range of 205's?
Any help on this would be appreciated.
Car is -
205 1.6 Gti
G reg = 1990 (Phase 1.5)
Thx in advance
Edited by Andrwn8304
All 1.6 GTi hubs are the same, with the exception of ABS models.
1.9 GTi and non-GTi (base model) hubs are different.
309 GTi hubs are the same as 205 1.9 GTi hubs.
Andrwn8304
So any 1.6 Gti hubs will fit is that right
Yes, any non-ABS 1.6 GTi hub will fit fine.
(reworded the original post to make it clearer)
Andrwn8304
Thx Anthony, will start looking for some now <_<
Andrwn8304
Just a follow up are the Hub Carriers the same aswell?
DrSarty
Surely the hub and hub carrier are the same thing?
The bearing fits into the hub/hub carrier, and everything else (wishbone balljoint, driveshaft, track rod end etc) all fit into or attach to the hub carrier as well.
hub is the drive flange, 1.6 specific, hub carrier = thing the wheel-bearing and hub are pressed into, not 1.6 specific, fits TU as well with the correct drive flange/hub <_<
