pugpete1108
Just A Quick One...
pugpete1108
as title really, i know the bore and pcd is the same but what about the offset? will they need spacers.
cheers
pete
Edited by pugpete1108
The offset is different on the 15" Mi16 alloys - ET29 compared to ET19 on a 205 15" alloy.
pugpete1108
so would need 10mm spacers to be th same fitment then and stop rubbing on the inner arches/struts?
yes 10mm spacers would be needed to make them the same offset as 1.9 wheels, but they may well fit straight on without, I did get some ET28 Ouragans/nimrods on my 309 without a spacer on the front and they are half an inch wider, the rear heels did have wider tyres and needed a 5mm spacer to clear.
if its 1.6 hubs on there even more chance they'll fit without spacers
tri_longer
I'm running 10mm spacers on the front and 3mm on the back on a 309 beam, which does come close to the arches but is fine.
buchanan84
i can also tell you, they do fir on 1.6 front hubs but need spacers (10mm) on a standard 1.6 rear beam
