splant
Reverse Light Switch [where]
splant
hi is the switch the one on top of the gearbox near the clutch cable lever ? ive not got a live to these wires if it is [brown and white]
although when i put a live to them hoping the reverse light will come on a relay clicks? on one wire and the other is earthed ,, the relay that clicks is one of them near the bulkhead .... but still no light at the back .
any suggestions ? cheers
HERMAN
Reverse switch is on the front near the top of the gearbox. I beleve that they are brown and purple wires. If you connect the 2 wires together this should put the light on. Note be1 (Reverse next to first) gearboxes have two small spade terminals in a plug. I can not vouch for the be3 (reverse next to fifth).
Have you fitted a new bulb? Also it is possible that the switch has a dead short the earth and this will cause it to blow the fuse when reverse is selected.
You can just see it in this picture. It is the black bit.
Edited by HERMAN
