Pugnut
Photographic Help Required
Pugnut
hi, tacking on my new roofskin and there's a discrepancy between the a pillars on the passenger and drivers side. theres 2mm or so play when the front crossmember is sitting in the channel, so i was wondering if someone could have a look/or take a picture of theirs to help me out. I dont think it would make that much difference in the fitting of the windscreen, but would rather get it bob-on before i go any further.
this is the photo of mine that i'de like to compare against. you can see the windscreen lip on the underside (inside radius) just poking through. i was wondering if someone could compare this against theirs.
TIA , Al
EdCherry
Just taken some photos for you will upload when I get back from the workshop
EdCherry
Hope they help a bit, can get some different angles if you need but not till sunday eve or monday eve.
Pugnut
Ed, they are great thanks. shows the cross member fully forward in the channel. the way the skin was fitting i had it tight at the back on one side and tight at the front on the other and i wasn't sure which one should go in which direction. only a MM or so in it, but work getting right!
Much appreciated.
