205wrc
Pts Spec Rose Jointed Bottom Arms
205wrc
Hi....
I'm posting this on behalf of a friend of mine (Jeff Skitt - J.S. Engineering), who makes these arms, and other parts for rally cars for a living. I will also be putting an advert in the for sale section with the prices / contact details etc.
The arms are made to the same spec as the PTS ones, with a rose joint on the outer end and rubber bushes on the inside.
The rose joint is the proper size - M20 x 16mm, with drop pins, top hat spacers and locknut.
There is a choice of which rose joint you want to use, either the RBJ79MG - which is the removable ball type with a grease nipple, or a rose joint that is teflon lined, and lasts much longer.
Photos of the arms are below, and all the components are also available seperately.
Jeff does a lot of Motorsport Machining work, from building Atlas Axles for Escorts to wheel studs and Bilstein Strut bushes -
basically if you give him dimensions of something, he'll make it for you.
Complete Rose Jointed Bottom Arm
16mm dia. Drop Pin
Top Hat Spacers
Teflon Lined Rose Joint
Teflon Lined Rose Joint and the RBJ79MG Rose Joint
Could be interested, pricing would be good. :(
Also interested in just a replacement drop pin & nut for my existing ones if posible?
205wrc
Just posted an advert in the for sale section with prices of the arms and individual components :(
Cameron
Definitely some of the better quality modified arms by the looks of it, nice work. :D
philfingers
welding looks good!
Bigtimmy
I must be going blind, (too many sunny hunnys these last couple of days) and I can't for the life of me find the for sale thread with the prices. Can someone point me in the right direction....Thanks :)
philfingers
it's in the group buys section, not far from the top!
Is this the same guy that did the non adjustable balljoint end replacement with a spherical bearing/ drop pin set up?
How much does he charge for those if it is?
Graaham.
205wrc
Graaham.
Yes Graham, it's the same person. I'll find out for you tomorrow and drop you a p.m.
Aled
