Paul Smith
Solid Rear Beam Mounts
Paul Smith
Hi
I have purchased some solid rear beam mounts but am unsure where the fit on the rear beam, I had a quick look last night and couldn't see anywhere obvious they would go ? Any help would be great
Paul
tomcolinjones
Hi
Paul
lift up your boot carpet (if you have any) and you will see 2 plastic circular bungs at each side of the boot space, pull these out with a screwdriver or something and you will see a bolt in each hole. and also if you get under the rear of the car where your rear exhasut mount goes onto the beam, there will be a nut, same on teh other side. the mount goes between these. you need to remove the rubber square shape beam mount if it is still there. make sure you put the exhasut mount back on... and the propper way around! personal experiance lol.
swordfish210
Hi
Paul
There's a guide to fitting them on the main site. FYI wrong section as well.
large
Also at the front of the beam you have a bushed mount that bolts to to the beam bracket that bolts to the boot floor.
tomcolinjones
Hi
Paul
oh ye, the y obviously go between the beam and the shell. i had to put a bolt through mine, not shore what type you have tho.
Its worthwhile but not ideal without fitting the uprated front bushes at the same time.
You also need the bolts which fit through the floor, bushes & beam arm to go with them that aren't pictured.
Graham.
richardjw
I used the article on main site, farily easy job. Just need to smuggle the front suspension into work to push all the front rubber out.
Whoever wrote the main site article, cheers!
shalmaneser
Hi I have bought this
http://cgi.ebay.co.uk/205-GTi-solid-rear-b...=item2a05bfc20d
Thank you for the advice so far, is it a worth while purchase? Not to worried just seemed a ood idea at the time
good upgrade with solid front mounts (do them at the same time, its a major PITA) but they seem a bit steep for two lumps of aluminium!
