steble
Brake Question No Access To Haynes Atm Lol
steble
i was just sitting here thinking my brakes could do with bleeding, not got a manual so couple of simple questions
what fluid do i need? i happen to have some halfords dot 4 in the shed is that ok?
and whats the bleed cycle on these?
shalmaneser
Dot 4 is fine but you shouldn't really use old stuff as it attracts moisture and the effectiveness drops. You need about 500ml for a whole system bleed in my experience.
Bleed cycle is as per normal really - just start on the cali furthest away from the master cylinder (ie rear NS) then get closer (RR OS, FF NS, FF OS) until you're done. It's a fairly easy system to bleed if you don't have ABS. I've got one of those one way valve things that makes the whole thing a one man job albeit with a lot of hopping in and out of the drivers seat.
blessed6383
belive the bleed order is furthest 1st then in and x pattern so passanger rear, drivers front, drivers rear, passanger front. correct me if im wrong but this is the way i've always done it
j_turnell
I'd firstly check the condition of your bleed nipples as more often than not there either already snapped or look worse for wear! Give them a wire brushing and spray some wd40 and leave to soak. I also use some heat on them just before i crack them off to reduce the risk of them snapping. Dot 4 should be ok, start furthest away from the MC so nrside rear - offside rear- nrside front- offside front. May need to go round 2-3 times to get a good pedal.
steble
cheers guys will go do it now,
just so happens i have about 500ml here :)
steble
ha ha guess what happened :)
i did the first 3 brakes no probel at all and then basically all i had to do was look at the last bleed nipple and it snapped :huh:
oh well its not leaking so i thought i'd leave that one for now ha ha brake pedal is much stiffer
i assume i have to drill it out then? and get a new nipple or is it not that easy
i also got covered in grease from the front n/s guess what! thats right you got it i need a cv boot :lol:
richardjw
WHen i tried to drill and tap my old caliper it was a failure. Had machine shop at work do it to. To old and soft to take a new thread. Got a 'new' one from a company called 'Big Red' a lot cheaper than i thought. If needed i can sort out contact details, i have their catalogue somewher under all the wiring!
steble
yer that would be great mate if you could
