DRTDVL
Trailing Arms For A 106
DRTDVL
Basically a friend is wondering if the 205 trailing arms will fit his 106 rallye...
Wasn't sure so i figured i'd ask here...
no, only arms from a 106 or saxo will fit.
DRTDVL
cool thanks for that...
Do you know if there is any differances in the 106 or Saxo arms?
not sure on camber or toe differences, but base model beams which dont have an ARB have different outer bearings which incorporate a steel end cap, though these can be removed and replaced with standard ARB type bearings.
I'm unsure if the stub axles are different lengths between disc and drum, there's also ABS and non ABS beams though that's not applicable to most Rallyes.
