c2v6
D8 V6 What Choice Of Gearbox Do I Have?
c2v6
Hi all,
iv got the chance of a coulpe of gti6 boxes to use in my twin v6 c2, Could someone please tel me if they will fit on the v6 motors?? if not what will??
Gary
Rob Turbo
You need to use a gearbox from the v6 engine, some v6's did come with 6 speed boxes if you really want 6 gears.
I'm afraid the only two options you have of manual boxes are an ML5 or ML6 gearbox, specifically from a V6 engine only.
c2v6
Ah hell....
whats the differance between the ml5 and ml6??
what sort of power will these boxes put up with before i start getting problems??
Gary
one is 5 speed and more common, the other 6 speed and not so common :)
you'll find the ML5 in Xantia's, C5's, 406's 605's 607's, possibly XM's and 407's, the ML6 was only found in the 407 I believe, I doubt you'd find a manual C6 so get one from!
not sure on power levels, but its torque that hurts a gearbox not power, and these cope quite well with the 2.2 HDI's torque levels.
Rob Turbo
The ML5 is 5 speed, the ML6 is 6 speed, boxes from both D8 and D9 v6 engines will fit, they are fairly bulletproof, especially compared to BE boxes, they weigh a ton!
c2v6
ah right learn something everyday anyway lol
thanks for that guys mucly apreciated
Gary
As said bar the ML on the Pug's nothing else on a normal H set up, They stand upto allot but I don;t think hardly anyone has gone that far in the power stakes yet but at a guess should see a good 300bhp
Don;t forget the Renault option/s but I have no idea about there's
