Jackman 0 Posted March 26, 2010 (edited) Can someone clear this all up for me please! I'm currently switching to a GTi subframe and am at the point of bolting on! I snapped one of the front bolts getting mine off, but was told they aren't fitted with these anyway and need to switch! (Even though my D Turbo has the same setup as my Rallye) I've been to peugeot today and bought the bolts from a GTi Where exactly do i put the nut? Thanks! Edited March 26, 2010 by Jackman Share this post Link to post Share on other sites
blessed6383 0 Posted March 26, 2010 not sure where they go mate but are you fitting the gti subframe to run a gti engne? if so no problem just fitted an mi16 in mine what was thought to be a gti sub frame only to find out it was but the gear linkage bracket had been moved to run a tu engine and box and it was welded in different place boy was i pissed lol Share this post Link to post Share on other sites
jaked 1 Posted March 26, 2010 Hi, not sure if this will help or not? Might help? I've been doing some searching as I'm re-fitting my XS subframe, and seem to have cross threaded one of the bolts that fixes the rubber mount to the chassis leg. I'm not sure how to tackle it as it's all pretty enclosed. It appears the gti subframe fixes differently to the chassis leg though than the xs, but I don't see why you can't just fit the gti subframe to your base model? Some of the posts in that topic might help. Jake Share this post Link to post Share on other sites
welshpug 1,645 Posted March 26, 2010 inside the chassis leg I think edcherry replaced one of his, might be worth asking in case he took some pictures. Share this post Link to post Share on other sites
trogboy 17 Posted March 26, 2010 You don't need to switch to the gti setup for the front mounting points. Just carry on using the stud/rubber mount jobbie that you have on the base model shell. This was covered a long time go but I think it came doen to differences etween the base model and gti shell WRT the chassis legs. Share this post Link to post Share on other sites
welshpug 1,645 Posted March 26, 2010 You don't need to switch to the gti setup for the front mounting points. Just carry on using the stud/rubber mount jobbie that you have on the base model shell. This was covered a long time go but I think it came doen to differences etween the base model and gti shell WRT the chassis legs. so the subframe legs are the same height but the chassis legs different Share this post Link to post Share on other sites
Jrod 7 Posted March 26, 2010 You don't need to switch to the gti setup for the front mounting points. Just carry on using the stud/rubber mount jobbie that you have on the base model shell. This was covered a long time go but I think it came doen to differences etween the base model and gti shell WRT the chassis legs. I used 309 ones as they are solid metal, not rubber. Share this post Link to post Share on other sites
trogboy 17 Posted March 26, 2010 so the subframe legs are the same height but the chassis legs different Yep - I think that was the conclusion. I modded a gti subframe to fit my rallye and compared the sub frames side by side. I don't remember there being any difference in that respect and I know it was definitely something that I looked at. Share this post Link to post Share on other sites
jaked 1 Posted March 27, 2010 Does anyone know why, on service box it looks like the bolt (6923.G6) goes down, through the chassis leg and rubber mount, with the nut below? On my car (and other pictures i've found), the nut seems to be fixed to the chassis leg, and the bolt goes up, through the rubber mount holes, into the chassis leg? I seem to have cross threaded it, and need to know how/whether to replace the nut, or if I just need to run a tap through it Share this post Link to post Share on other sites
Jackman 0 Posted March 27, 2010 I used 309 ones as they are solid metal, not rubber. After advice from Sandy i will be getting these aswell now! Part number is 352339 if anyone wants to know! Share this post Link to post Share on other sites
