Peetypug
No Cold Start Valve On My 1.6
Peetypug
since i bought my 205 it has been quite hard to start
sometimes taking 10 mins of semi starting and cutting out before it runs, then when its warm it has quite a high idle
anyway, today i got the chance to replace the CSV with a known good one only to find there isnt one fitted
is this right?
its a j plate 1.6 with a B6E engine code
i've compared it to the engine i bought off tom fenton and from what i can see thats the same but a B6D engine
do these codes sound right?
on my 1990 1.9 it had the SAD bolted to the CSV which in turn was bolted somehow to the thermostat housing iirc
can anybody tell me where im going wrong?
cheers
later cars had the SAD bolted directly to the thermostat housing with the CTS in the back of the thermostat housing not in the bit bolted on the side, should have one!
I guess the hose from the elbow on the intake is blocked off as well as the one on the bottom of the inlet?
Peetypug
so it is part of the housing?
not sure which hoses you mean
no, bolted to the housing, same valve as the earlier cars.
the hoses? the one that goes from the 90degree/K&N adapter, to the SAD, then to the inlet.
Peetypug
no, no sign of it at all, but the coolant hoses seem right
they are on it, the sad is bolted to the side of the housing but no sign of the CTS
err, sorry, massive brainfart on my part, I thought you were on about the SAD.
the CTS will be on the rear of the thermostat housing, near where the dipstick goes down the back.
the lower one shown here;
Edited by welshpug
You have now lost me completely. Lets start again.
On the earlier cars, the SAD is attached to a seperate alloy water housing, connected with rubber pipes to the thermostat housing, and also has the coolant temp sensor for the ECU there.
On the late cars, the SAD is attached directly to the thermostat housing. The coolant temp sensor for the ECU is at the back with the two other water sensors for the gauges on the dash.
thermohousingstn8.th.jpg Edited by welshpug
Peetypug
think you may have answered them for me there
i was looking for the alloy housing that tom mentions, not the sensor :lol:
this is what i ws looking for
yeah, you don't have them on post 91 cars !
Peetypug
that will be why i cant find it then :lol:
cheers gents, your help with my failings as a 205 enthusiast is very much appreciated
