splant
Which Relays Which
splant
i remember a post showing which relay does what , i knew i should have sketched it down any body know where it is or if not which ones for the driving lamps ? thanks
ade 4wd
Going from left to right:-
1-Driving lights
2-Not used on a 205
3-Front screen wiper delay
4-Indicator/Hazard
5-Electric windows
6-Heated rear window
Ade,
splant
mine has nothing in the first on the left but relays in the rest.... 2nd one also ? what sort of relay do i need to put in to get the spots working? cant find any on ebay ?
large
Well, will the one from the second slot fit the first?
ade 4wd
Move the relay from position 2 to position 1. 205s dont use a relay in position 2.
splant
thank you all ,,,done it [ pulled out of 2nd put in 1st ] and it worked after cleaning the connections up on one of them hooray still expecting something not to work though why was it put in the 2nd hmmmmm its a 92 model are you sure its not used for summat ..
ade 4wd
Relay in position 2 is used for rear electric windows when used in a citroen BX.
