splant
Driving Lamps Not Working
splant
are they supposed to work with the high beam are they just spliced into the high beam circuit somewhere ,will they have there own fuse mine have a lot of lines down the lenses and not very clear does this mean theyre fog lights ,,also my reversing lights not working [ bulbs and contacts all fine on both} ,,, thanks for any suggestions
P_Monty
It looks as though they are fed from their own relay which is energised by the main beam circuit. And yes, they are driving lights.
They are driving lamps, only come one with full beam.
Reasons for them not working can be as simple as a blown fuse but the yellow plug for each one near the headlamps can also become corroded & stop them from working.
They should have their own seperate fuse #4 15A;
Fuses (1991 models onward);
1; Reversing lights, tachometer, fuel gauge, warning lights (low battery charge,
coolant temperature, oil pressure, low coolant level, brake system, choke). . . . . . . . . . . . . . . 10A
2; Direction indicators, gauges (fuel, oil temperature, coolant temperature, oil pressure),
heater blower motor, warning lights (low battery charge, coolant temperature, oil pressure,
low coolant level, brake system, choke, ABS) . . . . . . . . . . . . . . . . . . . . 25A
3; Map reading light, stop-lights, windscreen and tailgate wash/wipe, tachometer, radio, glovebox light, heated rear window . . . . . . . . . 25A
4; Driving lights . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15A
5; Hazard warning lights . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10A
6; Spare
7; Clock, interior lights, luggage compartment light, central locking, radio, power feed to tow bar . . . . . . . . . . . . . . . . . . . . . . . . . . 25A
8; Horn, heated rear window, cigarette lighter . . . . . . . . . . . . . . . . . . 30A
9; Electric windows . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20A
10; Rear fog lights . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5A
11; Tail lights . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5A
12; Spare
13; Instrument panel illumination, side lights . . . . . . . . . . . . . . . . . . . . 5A
14; Electric fuel pump . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15A
Fuse from a phase 2 owners manual;
1; Reversing lights, tachometer, dim lights, fuel gauge, water in fuel sensor (diesel), warning lights (low battery charge, coolant temperature, oil pressure, low coolant level, brake system, choke). . . . . . . . . . . . . . . 10A
2; Direction indicators, fuel gauge, seaty heating, additional heater / ventilation pump, oil temperature guage, coolant temperature guage, oil pressure guage, heater/ventilation; air conditioning, warning lights (low battery charge, water in fuel, coolant temperature, oil pressure, low coolant level, brake system, choke, ABS) . . . . . . . . . . . . . . . . . . . . 25A
3; Map reading light, stop lights, windscreen and tailgate wash/wipe(front & rear), tachometer,
headlamp wash, radio ( accessories), glovebox light, heated rear window . . . . . . . . . 25A
4; Spot lights . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15A
6; Spare
7; Clock, interior lights, luggage compartment light, central locking, radio (+ permanent), power feed to tow bar . .. . . . . . . . . . . . . . . 25A
9; Electric windows . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25A
11; Rear side lamps - left: number plate lamps. . . . . . . . . . . . . . . . . . . . . . 5A
12; Rear side lamp - right. . . . . . . . . . . . . . . . . . . 5A
14; Electric fuel pump . . . . . . . . . . . . . . . . . . . . . . . . . . . 15A
For the reversing lights, if the fuse is Ok, remove the plug from the gearbox (bear the clutch arm) & bridge the connector pins to seeifit comes on. They only work with the ignition on the second click iirc though.
