james_ix
Original Fuse Sizes
james_ix
Hello
I have been searching in vain for the original fuses sizes relevant to the fuse location for the 205 GTi 1900.
i.e. which size fuse goes in position 1, 2, 3, 4 and so on
Can anyone inform me or let me know where I can find this information.
I want to check that the correct sized fuses are in the correct positions as over the years I am sure my 1990 H-reg ph 1.5 has them all mixed up.
Thanks in advance
ade 4wd
A quick use of the search feature;
thanks to Rallysteve.
Fuses (early models)
No Circuit protected Rating (amp)
1 Reverse light, cooling fan relay, tachometer (GTI) ............ 10
2 Accessories, indicators, fuel gauge, warning lights,
heater blower motor ........................................... 25
3 Ignition switch, wash/wipe system, stop-lights,
tachometer (non-GTI option), radio, heated rear window,
electric window relay (option),
clock illumination (GTI) ...................................... 25
4 Central door locking (option) ................................. 10
5 Cooling fan ................................................... 25
6 Hazard warning switch ......................................... 10
7 Spare ......................................................... -
8 Cigarette lighter, clock, interior lights,
glovebox illumination, radio .................................. 20
9 Electric front windows ........................................ 25
10 Heated rear window, horns ..................................... 20
11 Rear fog light ................................................ 5
12 Side/tail lights/warning light,
instrument panel illumination, number plate lights ............ 5
13 (In-line) fuel pump (GTI) ..................................... 25
Fuses (1986 to 1988 GTI and CTI models)
1 Reversing lights, tachometer .................................. 10
2 Direction indicators, heater blower motor, oil pressure gauge,
oil temperature gauge, heated seats, fuel gauge,
coolant temperature gauge, low battery charge warning,
oil pressure warning, brake system warning,
coolant temperature warning, low coolant level warning ........ 25
3 Windscreen wiper/washer, stop-lights, headlight washer,
radio, accessories ............................................ 25
4 Spare ......................................................... -
5 Hazard warning ................................................ 10
6 Spare ......................................................... -
7 Cigarette lighter, clock, interior lights, boot light,
central door locking, radio ................................... 25
8 Horns ......................................................... 25
9 Electrically-operated windows ................................. 20
10 Rear foglight ................................................. 5
11 Tail light (RH), number plate light ........................... 5
12 Tail light (LH) ............................................... 5
13 Instrument panel illumination, side lights .................... 5
14 Fuel pump ..................................................... 15
Fuses (1988 to 1989 models, except GTI and CTI)
1 Reversing lights .............................................. 10
ignition warning light ........................................ 25
3 Fuel gauge, stop-lights, front and rear wash/wipe,
tachometer, headlight wash, radio, storage tray light,
warning lights (coolant temperature, oil pressure,
coolant level, handbrake, choke) .............................. 25
8 Horns, heated rear window ..................................... 25
10 Rear fog light ................................................ 5
11 Tail lights, number plate light ............................... 5
12 Spare ......................................................... -
Fuses (1988 to 1989 GTI and CTI models)
3 Front and rear wash/wipe, stop-lights, headlight washer,
radio, accessories, storage tray light, map reading light ..... 25
central door locking, radio ................................... 20
11 Tail light, number plate light ................................ 5
12 Spare ......................................................... 5
Fuses (1989 to 1991 - all models)
1 Reversing lights, tachometer, fuel gauge, warning lights
(low battery charge, coolant temperature, oil pressure,
low coolant level, brake system, choke) ...................... 10
2 Direction indicators, gauges (fuel, oil temperature,
coolant temperature, oil pressure), heater blower motor,
warning lights (low battery charge, coolant temperature,
oil pressure, low coolant level, brake system, choke) ......... 25
3 Map reading light, stop-lights, windscreen and tailgate
wash/wipe, tachometer, radio, glovebox light, electric windows,
heated rear window ............................................ 25
4 Driving lights ................................................ 15
5 Hazard warning lights ......................................... 10
7 Cigarette lighter, clock, interior lights, luggage compartment
light, central locking, radio, power feed to tow bar .......... 25
8 Horn, heated rear window ...................................... 25
9 Electric windows .............................................. 20
11 Tail lights, number plate lights .............................. 5
14 Electric fuel pump ............................................ 15
Fuses (1991 models onward)
oil pressure, low coolant level, brake system, choke, ABS) .... 25
tailgate wash/wipe, tachometer, radio, glovebox light,
7 Clock, interior lights, luggage compartment light,
central locking, radio, power feed to tow bar ................. 25
8 Horn, heated rear window, cigarette lighter ................... 30
10 Rear fog lights ............................................... 5
11 Tail lights ................................................... 5
Fuses in engine compartment
ABS .............................................................. 30
Power supply to ABS electronic control unit ...................... 15
Cooling fan ...................................................... 30
Oxygen sensor .................................................... 10
james_ix
Wow thanks Ade 4wd
What a quick response!!! So that's me in the glove box tonight.
Your information also made me realise why my horn switch on the stalk was not working regularly... The rear window heater does not always switch on and looking at the list the rear window heater and horn share the same feed. I fixed the rear window heater problem last night by cleaning the contacts on the relay, so I will check the horn also.
:huh:
