foreigner
Anti Roll Bar, I Think I Put It Wrong Way Round?
foreigner
I have been trying to find a picture of arb fitted corectly.
Has anyone got a picture?
foreigner
Does the bend on the bar goes up or down?
I can't remember at all??
down then forwards IIRC, i'll see if I have a picture :)
the bulge goes on the Left hand side of the vehicle;
Edited by welshpug
It's obvious enough if you look under the car - the bend should align with the exhaust, otherwise there's sod-all clearance there...
foreigner
Thanx , just before everything else was installed, phew.
foreigner
Problem was that exhaust not there yet
SurGie
WP, by left hand side of the car, do mean the near side ?
The bushes are different colours for each side so that should tell you what way it fits.
Blue on right & orange on left iirc.
SurGie
My 309 ARB bushes are both black ?
quite probable, specially if aftermarket, graham described the standard 205 gti bushes.
309 bushes are a larger size & iirc either dark grey & black or both black when they were available.
For 205 bushes, aftermarket ones probably cost more for an inferior bush as well.
Both 205 bushes from Peugeot (5094 42 left 5094 43 right) are (or were) under £10 (cheaper than ebay) last time I got some but the only downside is they often come in twos so you end up with a spare set.
