tdr_1976
205 Xs Caliper And Disks Question
tdr_1976
Hi,
After a run on the back roads the other evening with my navigator, I experienced brake fade again.
I've decided that I have to go to vented cross drilled/grooved disks to try and give additional cooling to the disks and pads.
My question is;
I know that the 1.6 GTi Carriers will fit straight onto my caliper piston assembly [std 205 XS one], but I'm not sure whether the disks are a straight on fit?
I've upgraded my brake fluid spec from DOT 4 to DOT 5.1 last week, it's helped, but I still get fade.
1.9 discs ;)
tdr_1976
1.9 discs ;)
Nice one mate!
Thanks for the reply :lol:
no probs, as said many many times on the forum, base model hubs are the same offset as the 1.9, though have the same smaller spline pattern as the 1.6 ;)
tdr_1976
Thanks for the explanation mate!
I wasn't sure why the 1.9 would fit, whilst I was using 1.6 carriers!
