Silky
8v Wiring Help - Essex
Silky
Recently changed engines over, the engine in there now has a slightly different loom which I am having problems with.
I've wired in as much as possible, tho still have some spare connectors and not sure where they go.
Ideally I'd like someone local with a P2 to pop over and give me a hand with the loom, even if it's just copying what you have so I can see if I'm missing anything
If you think you can help and don't mind popping to mine then please let me know
I just want to compare loom connections, where it runs, connects etc.
Anyone in the Essex/Kent/Herts area who could help would be fantastic
If I can't get it fixed then I'd be tempted to sell the lot, it's only a silly problem, probably something not plugged in.
If I sold it it'd go with coilovers/cage/buckets/harnesses etc etc etc
Tax'd and Mot'd and cheap
j_turnell
whats actually the problem with it mate?
Silky
I put another 8v engine as previous one had a dodgy loom.
This one is all good, but I don't know how to connect it up, it's all in and is probably something really silly like a wrongly connected part of the loom. I just need something to copy but I'm going to the ring in 2 months and if I can't get something to check it against then I'll look to sell it and buy something for the trip
To be honest, the looms are very straight forward and you shouldn't really need another car to copy
The plugs and wires are obviously fairly close to where they need to plug into, and some of it is colour coded
4 x black 2 pin plugs = injectors
Blue 2 pin plug = ECU temp sensor
White 2 pin plug = reverse switch
Black 2 pin plug near the above two = SAD
Black 3 pin plug with normal wire = TPS
3 pin plug with shielded wire = dizzy pickup
Black 5 pin plug = AFM
Black 8 plin plug = ignition amp
2 x Green wires with ring terminals = earths
Brown 4 pin odd-shaped plug = coil
Thick brown wire = +12v feed from shuntbox
Spade with brown wire (7A) = alternator exciter
Spade with blue wire (46) = starter solenoid
That should get you started.
floodys
sell the car silks!! your to hasty!!! calm down man, its only a GTi!!! lol, i'll see if i can pop over this weeknd and do it for you!! floods to the rescue again.....
Silky
Brilliant, cheers Anthony.
To be honest most of that one is done, i'm
also struggling with the engine to fuseboard loom
Silky
I've got a square 3 pin plug up behind the battery next to the ignition amp....what's that for ? It's only on a short piece of wire so can't go far
If it's on the engine loom, that's probably the one that connects to the dizzy pickup - with that unplugged, you'll have no spark or injection. Should be a shielded wire, so feel a thicker/stiffer than the others.
Silky
It's on the loom which comes through from the fuseboard
Pop over and have a look at one of mine if you like mate, take pics etc! I'm only have one that doesn't have injection on the road at the mo so not much use!
kate205gti
i'm aiming to have mine running for combe 24th april - i'll bring it over as soon as its running if you havent sorted it before then :huh: its not a p2 but cant be that much different
Silky
I may have to do that mate, if Ian can get over and run an eye over it I may be lucky, but then again you may see me at yours with a camera
Errrmmm... there's the plug for the level sensor at the bottom of the expansion tank that's 3 pin, and there's a white connector (which I thought was 2 pin) that's to the right of the expansion tank that's is where the ABS connects to the main car loom if fitted. Those are the only two that immediately spring to mind.
Silky
Thanks Kate, much appreciated. You should have your bits from me by tomorrow, they're in two seperate envelopes
Silky
If anyone is available this weekend then please let me know, any help appreciated.
I go to the ring in about 8 weeks and 4 of them I am either away on holidays or have weddings etc, so I have little time to get it finished let alone get the cage/buckets etc welded in and do the rest
Silky
If anyone wants to have a go at fixing the loom issue then £50 to whoever can
M@tt
get some pics up of the connectors your stuck on i'm sure between us we can sort it.
Have you checked for any wire numbers on the wires near the connectors. Give the wires abit of a rub with a rag and some wd40 to remove any dirt or oil and see what you can find.
Silky
I'll try and get some pics up though likely to be the weekend as it's too dark of an evening to take any decent ones.
The problem I have is that I may have put some the wrong way round therefore causing an issue
M@tt
How about remove the loom take a picture of the loom all laid out on the floor and edit the pic in paint or somethign and add a number to each of the connectors. We can then tell you what each connector goes to
Silky
It's the fuseboard to engine loom I am working on
I've got all the headlight bits etc in, it's just a couple of others, plus I reckon the starter may be wired incorrectly.
I had to change the starter that was on the engine as some of the wiring was different, thought I had it correct but maybe not
Grim.Badger
The easiest thing is to just go around the engine bay checking that every component is connected up properly; as we all now there are a fair few spare connections in the GTi loom anyway.
Alternatively, you could post up pictures or descriptions of each loose connection ;)
Silky
Hoping the weekend is going to be dry so I can get out there and have a look.
I will get pics/descriptions of the spare connectors fuseboard side
However, could someone describe/tell me how the starter and alternator should be wired up as I might have that wrong
I already told you that further up the page. What's the point in asking for help and not actually reading what people say when they take the time to try and help you? :D
Indeed, why on earth have you got three threads running all on the same thing, and why have you put the same reply in all three?
Silky
Yep you're right Ant
I have actually printed off those little notes you made above to give it a go and check at the weekend, so thanks for those
What with going to work and returning home in the dark and not able to do anything its very frustrating, I just want it to run !!
Edited by Silky
floodys
Dont worry everyone!! i'm going round to claim my £50 and sort this little problem for mr siks at the weekend!!
