bigryrs
Gti6 Custom Water Hoses For 205
bigryrs
im currently fitting a gti6 engine into my 205 and im wondering if there is any company that sells complete kits for this so i dont have to muck about chopping stuff up lol
CosKev
Not much to change really :(
BBM do a hose for the rear pipe from header tank.
They also do a thermostat housing adapter,which alloys you to use 205 thermostat and housing,and top hose :)
bigryrs
i have the thermostat adapter and top hose from bbm but its just the rear hoses that plug into the 205 body that im needing
CosKev
Did you keep hold of old standard hoses?????
Most of them fit :)
bigryrs
Most of them fit :)
yeah ive got them all but my mate who has done this conversion says he had a nightmare chopping up hoses etc to make things fit
yeti-dj
Hey fella, found some pictures of what you need to make or the silicon one you need to buy
maybe someone on here will let you know where you can buy it from..
offshore?
what it looks like in car
hope this helps
A Stat to Rad pipe is due soon as well
bigryrs
where can i buy the hose from then??
from Miles or BBM.
bigryrs
problem solved cheers
Alastairh
I have thought of a new way to plumb in the gti6 engines into 205s without any t pieces or rubber hoses down near the manifold but routed the same as a 205. I am trying it out on mine first to see if it works, but I'm certin it will.
Al
