stubby205
Heater Problem
stubby205
hi guys i have a 1991 205 gti 1.6 and last year my heaters stopped working, after dismantaling the dash to get to the heater fan and then realising i didnt have to i got the fan out and got another from scrapyard. i fitted new heater fan and still nothing i checked the conector on the fan dial and the little metal connector had fell off, so i glued it back on in place and now the fan works but only comes on full blast when dial is turned half way. to top it all when the fan is on and i turn my lights on the fan goes off :lol: i was having a fiddle today with the light/indicator stalk and when i unplugged the dimma dial under steering wheel the heater fan worked while lights were on then stopped when plugged dimma back in. im now stumped and any ideas would be more than welcome thanks john.
Edited by stubby205
Its more likely to be the control resistor, a small electrical panal held into the heater fan body by two screws thats stopping your fan from working.
The other bits sound like you might've disturbed an earth point when you took the dash apart & missed reconnecting it.
Graham.
stubby205
thanks so basically i should take the dash off and check everything is connected properly? and check the fan resistor.
