finnthebt
Front Subframe Captive Nuts
finnthebt
Hi, does anyone know if the captive nuts in the front chassis leg (205) for attaching the front subframe (the two single bolt fixings) are still available?
Doing a subframe swap and had to cut one of the bolts off as the captive nut was spinning.
Thanks.
B1ack_Mi16
Thanks.
If they're out of production I'm sure you can find some easy on a 405 at the scrappy.
I think they use the same ones where the big cast iron metal lump is bolted over the top enginemount.
At least if the bolts we are talking of is M10 ones?
GTI6BOY
they are still availiable yes
finnthebt
Done some searching/phoning around this morning - no longer available from Peugeot, but I think I have found a dealer with some stock. Will post details once confirmed.
finnthebt
OK, the Peugeot dealer near Bedworth & Nuneaton, Arbury Peugeot of Bulkington, has some in stock. The part number is 694181. The phone number for parts department is 0844 5585482.
Or PM me and I can send some out for £5/pair inc postage
