AJA_GTi
Rear Ride Height
AJA_GTi
Hello,
Just did the well arch ride height test and I can get 3 fingers in on the N/S (waits for the giggles :) ) and 2 plus 5mm slack on O/S.
Does this mean I need to adjust the torsion bar or sommat else?
Cheers, :)
marksorrento205
Dont worry about it. Pug say as long as its within 10mm either side iirc. The car will always be driven with a driver, not always a passenger......
AJA_GTi
Spot on mate that makes sense. Good job i'm no bantam weight :lol:
Laters :)
Edited by AJA_GTi
jord294
does your beam look like its been refurbed in the past ??????????
Measuring against the plastic arch isn't particularly accurate to be honest, as it could easily be a few millimetres out side to side.
Better bet is to measure against the jacking points and some flat level ground, checking all four corners (make sure the jacking points are still straight first though!)
AJA_GTi
Not sure mate - how can I tell? Look for clean shiny bits??
AJA_GTi
Mate - it handles impecably but someone at work said it looked a bit p*ssed on the gravel car park thats all.
I must admit i'd imagine the arches are out rather than anyling else as it's seriously on rails.
I'll do a more scientific test as slipping 2 fingers in always ends up bad :( sorry!
