Jose
What Exhaust Is This?
Jose
Hi all,
Can anyone tell me what make this exhaust system this is?
Also i believe it has come off a Mi16 205, will this also fit the 8v 1.9 and 1.6 205 GTi? are they the same size and fit etc?
There are some numbers stamped on them, see the photos below
Jose
a magnex i believe :)
possibly the type to be used with a magnex manifold, but never seen one of those up close to comment for definite but the foremost length of pipe does seem long enough for that, not the end of the world though as its easy to adapt it to suit another downpipe.
it can be fitted to a 1.6 or a 1.9, and a gti6 with the right downpipe.
Edited by welshpug
Jose
Thanks Welshpug
What your saying about the downpipe bit i think is correct!
When i had my 1.9 8v 205 i lined the exhausts up with the standard system and the pipe section in front of the mid box was longer than the standard one
So i take it you mean 8v 1.6 and 1.9? and the Mi16 205 and GTi6 engined 205?
Jose
right, it'll fit a 1.6 and 1.6 as long as it has the appropriate manifold, or is modified.
it'll fit up to an Mi16/gti6 as long as its modified to fit whatever downpipe you use :)
