kate205gti
What Size Are Wishbone To Subframe Bolts?
kate205gti
the ones from the wishbone arms to the subframe please?
getting some High Tensile ones off baz for balljoint and hub to strut but still need the other ones :)
cheers :)
front are M10 x 60, they do have a fairly long shank form memory, the rears are M12 x 65, again, with a fairly long shank.
fatony1
Anyone have any idea of the size/thread pitch of the nyloc nuts? Are they metric fine? :)
boombang
I've got a full set of Pug wishbone bolts if you are in need. Even better if you passing Brentwood, they'll be a bugger to post with the weight.
fatony1
Old or new?
boombang
Brand new, still in the bag.
front nuts are M10x1.5, rear ones are M12 x 1.75.
there is a change in the rear bolts+nut to a different spec for later cars ("SINCE DATE 1992 02 03") thread pitch altered to M12x1.25 (and increase in price)
though the wishbone bush kit is listed as having the earlier bolt+nut inc, whether this is the case or not Alex could confirm with his new bolts :(
wildejon
Handy link here
kate205gti
you cant buy the rear wishbone to subframe bolts from peugeot :D part number 3522 22 is a kit of 3 bolts including a subframe bolt, a front bolt, and a random full threaded gold bolt ;) the guy had no idea how to get the right bolt either
any idea where i can get 2 M12 x 1.75 shanked bolts from please? :)
