Carbs4me
Twin Dellorto's 40's Dhla Questions?
Carbs4me
Hello All,
I got myself some carbs the otherday, DHLA 40's, basicly i got given them from a friend. Afew parts are missing such as the butterfly's etc, 90% of the parts are there.
Im wondering what i require to get my G reg 1.9 205Gti to run on these carbs, and what size jets do the carbs require... bare in mind there is no manifold or fuel pipes just the carb's. i will supply pictures tomorrow, and also the process of reconditioning them, is it wise to do it myself or give them to a company that will be able to sort them out.
Also i plan to polish the whole things to make them look shinny, is there anywhere i shouldnt polish such as the face where the gaskets seal etc... Any advice or questions welcome :(
Carbs4me
Can any1 help with this i have tryed searching the forum but most post have links within them once you follow, the page no longer exists...
Any tips are welcome... and will provide pictures
MrG
the posts are out there, have a look in specific forum sections such as the the XU performance section as this has been covered a few times.
Also on the front page of this site is a section which lists how to do certain things listed here >> look in articles Go to the article section and there in engine conversions is fitting twin carbs.
Basically you need at least the following:
the carbs, inlet manifold, pressure regulator and possibly a new fuel pump (depends if you want to replace or keep the std one) new fuel hoses and air filters plus get a rev limiter.
The reconditioning is fairly straightforward, parts are available via the likes of ebay etc, just take your time and make sure everything is cleaned (using a good cleaner!) and put back together correctly. Do a search online and find details on the carbs, pictures tell a thousand words etc
The jetting I can't help you with, but I think getting them running on idle and to use is fairly easy but a rolling road session is needed to get the right ones fitted.
Fitting is straightforward, I did it on mine and I'm hardly a mechanic but be clean and methodical and you'll be fine.
