lemmingzappa
Rear Lights Rust
lemmingzappa
Took my rear lights off yesterday to find this:
Not alot I can do about it though I guess, only thing i've done so far is dry it out with a hairdryer.
davepug205
Ive repaired both sides on mine, just cut the rust out and made a plate to weld in, then covered in seam sealer and painted.
It joins the rear bumper mount so you might have to make a full piece up. Just dont weld to close to the rear arch otherwise you might have to respray. :)
lemmingzappa
I need new bumper mounts anyway as mine have rotted.
Unfortunately I have no metal or welding skills :)
Ohh dear, more Ph2 tinworm. :)
lemmingzappa
I seriously need to buy a welder and actually learn... but as per usual, funds are the main problem.
Another fairly common place for them to go I'm afraid, Pain to get to as well,
davepug205
Ah yes my shell was upside down when I repaired mine :) forgot that bit :)
lemmingzappa
If this area is left is it likely to spread to somewhere more major ?
I imagine it's quite hard to keep it dry due to water spray from underneath and rain from the light seals.
harryskid
Had the same problem i plated mine with the car upright very tricky to do though.
Harryskid :)
lemmingzappa
Harryskid :)
Did you cut the plate out and weld a whole homemade piece in ?
Is all the cutting and welding done from underneath the car ?
harryskid
I made plates to size of damage welded from inside where i could and from underneath but i use to do welding when i did industrial heating work. Welding pipes was very good practise for this kind of thing.
Harryskid :(
