sharpy
Coolant Temperature Sensor...which 1?
sharpy
Hi, have a peugeot 205 1.9 with a gti 6 engine in it. I have been told by others on here that i may need a coolant temperature sensor. Once i started looking for this part, people have told me there is a few variations of this part. Can anyone tell me which one i need, or how i can tell which one i need? Thanks alot people :D
chrisj21
Is it the ECU temp sender or the dash display sensor?
If it's the ECU temp sender (the brown one i beleive) service box list only one option 1338 55 @ £31.76
Chris
ecu temp sender for the gti6 ecu is the green one.
sharpy
Oh right :S so it's the green or brown? IS that definatly what it is? thats what people have said, coolant temperature sender..?
Green, brown one is the Bitron sensor iirc for the aircon iirc & not used on the 205.
Usually the loom plugs are the same colour as the sensor they fit (& also keyed so you can't normally cross connect them).
Graham.
green-ecu , brown-dash display, blue-aircond
No! brown is for Bitron A/C and Fan control unit, blue for the dash.
