custard-rallye
Ford Wheels
custard-rallye
hi i have found a set of wheels im going to get i think but the offset is 40 on a 7 j rim will they go on my uk 205 rallye without sticking out miles and would i need spacers??
You'll need spacers to use ET40 rims, especially if they are 7" wide.
Also the centre bore of the Ford alloys is smaller iirc so they wouldn't fit onto your hubs anyway.
Graham.
GeorgeXS
Graham.
Surely if he's going to need spacers the centre bore wont be an issue??
Edited by GeorgeXS
Daviewonder
It will if he gets hubcentric spacers for a peugeot.
hcmini1989
Graham.
im confused are you talking about genuine for alloys or ford fitment alloys here ^^^.as i had a set of oz turismos and they were ford fitment.and never had any issues with the cenre bore .but they were the wrong offset
custard-rallye
they are 4x108 so they should go straight on just need spacers
Jrod
Not if they have the wrong centre bore still.
It's not a problem anyway as you can buy Ford to Peugeot spacers.
custard-rallye
i got group a compo th's in ford fitment that needed the centres bored out i got it done by a machining company but i thought it was juset cause they were group a ones that the centres were different
Jrod
Ford use 63.4mm centre bore, Peugeot 65.1mm.
Both, genuine or aftermarket Ford fitment alloys have the wrong offset but aftermarket alloys might not have the problem with different bore sizes, I'll have to check the OZ super turismos which were fitted to my 306 when I bought it & see but they had 20mm spacers fitted which would've fixed the size difference anyway..
Graham.
