DRTDVL
309 Control Arms
DRTDVL
Hello... before you all just on the just search... i spent 2 hours trolling the forum last night... and yes i'm probably very useless at searching...
For some reason i was under the impression that only the 309 GTI control arms where suitable to use in the 205, last night i was hunting through the parts catalog found the following models have the same part number listed for the control arm.
CARBURETTOR XU92C
http://www.stuartmcguire.co.uk/pug/GB/309F/3/35B15A.HTM
INJECTION XU5JA XU9J1 XU9JAZ XU9M
http://www.stuartmcguire.co.uk/pug/GB/309F/3/35B25A.HTM
INJECTION XU9J4
http://www.stuartmcguire.co.uk/pug/GB/309F/3/35B35A.HTM
Is there any difference between, stronger, weaker, ball joint size, etc...
If there isn't it would make it much easier trying to find a set.
j_turnell
AFAIK they were only fitted to the gti and the Dturbo.
turbo diesel models use them too, wont make them any easier to find I doubt, they are under the same part number after all.
I know Motaquid don;t sell them anymore so I doubt Peugeot does, Your only choice is the low quality Far Eastern ones
j_turnell
I've always found quinton hazell good quality parts, which are listed on the link above.
