Jrod
What To Do?!
Which engine?
50 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Jrod
I have my plan sorted!
I'm going to do a basic rebuild of Engine 2 (HG, Valve stem seals, waterpump etc...) then fit this. I will then Rebuild engine 1 in my own time.
Heres a shot of the camcover from engine 2 I took today, I'm sure this must of been replaced and sat as they don't usually look this good do they?
pug309twin40s
that cam cover looks nearly brand new...
Jrod
Had a quote for the repair work to engine 1, £200-250.
I'm going to go ahead with this soon.
Jrod
Pulled the head off engine 2.
Nearly no corrosion on the head (which is more than can be said for engine 1!)
Can't feel any lip on this at all.
Edited by Jrod
It does look nice & clean inside, maybe it really was a 10k engine. :D
The rust on the liners would tie up with one that had been stood for a while but the block doesn't show the same rust from infrequent coolant changes imo.
Jrod
The coolant that came out was bright green and looked nice and new.
Jrod
Ah yes forgot to add.
The headgasket.
dale205mills
How about cut your loses and sell me both your engines :mellow: I have got two gti6 engines and 3 1.9 engines sat under my work bench and I am allways on the look out for junk. Did your 405 come from motomex in havent at all????
Jrod
JUNK!? :D
Feel free, take the shell while your at it. :blink:
It came from a very ghetto estate in Havant but he said he got it from a garage so I don't really know.
pug309twin40s
that engine looks very good, you can clearly see the honing marks on the liners and that headgasket doesnt look that old!!
Put an 8v in it with more power than any 16v. They're fun. :mellow:
Jrod
The main question is, does this look like a 123k mile engine. If not it's likely it has been replaced and that's got to be good news.
pug309twin40s
no its does not look like a 100+k engine, from what the pic's shows,
so i would say it is a 10K old engine..
Jrod
So the possibility is my luck might finally be changing and it won't blow up within a week, woo. :ph34r:
Jemehan
It makes sense and depends on car choice.
I'm so torn whether to have the 205 and another Capri or sell all my toys and get a Clio V6/Monaro/big expensive car...
If i were you, I would keep the Capri and the 205. Trust me when i say you will be dissapointed with a clio v6 or whatever... my 205 came off the road and i got stuck with a 'modern' car (most modern ive had '97 P reg). Hate it, drives itself, no risk, feels the lifeof the drive has been taken, I have a 205, mates have some capri's Keep it oldschool. you WILL kick yourself if you dont! oh, and the 10k engine would be better in my opinion....
