wardy18
Rose Joints Boots
wardy18
Hi all,
I have noticed recently that you can now buy Dust Seal Covers and Boots for your Rose Joints
Sealings Boots
and
Dust Seals
I currently have the Compbrake full rose joint wishbones and would love to look after the rose joints a little better, does anyone have any experience with these already?! Do you know what size boots i would need for the 2 smaller Subframe Rose Joints and 1 larger hub rose joint?! Also i have reducer bushes inside my rose joints so the bolts fit snugley so i really have no idea what size boots i should be getting?!
Any ideas
regards
Simon
swordfish210
They work pretty well, we used to use them on the Radicals at particularly dusty circuits. I think they were Aurora ones that came with the rod ends.
Rippthrough
The full neoprene sealing boots are great.
wardy18
Great, just need to work out what size i need
when they say, for eg, M14 Rose Joint, what part of the rose joint does this relate to:
1) The Male/Female Thread Size
or
2) The actual moving joint hole for the securing bolt to go through
Knowing this allow me to measure mine myself
S
Rippthrough
or
S
Generally the thread and the bore are both the same size on most joints, but just in case yours are, go on the external thread size as that's more closely related to the size of the body.
To be honest, the things are so stretchy that they'll probably fit everything from M12 to M18 anyway.
wardy18
Great ill get some ordered, they look like an awesome idea as the dusty rose joints have been on my all the time!!
Where did you get yours from?! Those on ebay are the only ones i can find
Rippthrough
I get mine from McGill too, they're about the best ones available.
wardy18
Great thanks, ill get some ordered, like you said ill order some smaller ones and they'll stretch to what i need im sure
