dumbiron
Quick Flywheel Question
dumbiron
I have had a search around and not found the answer i am after so...
I am currently converting a 205 1.6XL from automatic to manual, I have stripped everything i think i am going to need off the doner car (1.8 GLD) so have a BE3 gearbox.
The XL is a '92 model so has the single point injection fitted.
So the question is what choices of flywheel do i have ?
Thanks in advance.
Steve
It all depends on what engine management system you intend to run it on when you've finsihed the conversion.
The single point injection flywheel has a crank sensor which is needed for the ecu so if yu stick with this system (although its not suitable for the GTI engine) then you need the flywheel from either a late cat equipped 1.9 GTI, 306 1.6, 1.8 (8 & 16v) or an Mi16 flywheel (but this needs a different clutch).
I can't help but think that the diesel box will be quite unsuitable for a 1.6 N/A engine.
dumbiron
The only reason i went for the diesel box is the fact that there was a spare diesel car parked in my back garden. The (ex)auto is just a toy at the moment so will probably be developing for many months to come yet.
Thanks for the flywheel info ^_^
dumbiron
How about this ?
XANTIA FLYWHEEL STARTER RING GEAR 97 1.8DOHC XU7 JP4
bit useless on its own :) you need the whole flywheel!
dumbiron
bit useless on its own :lol: you need the whole flywheel!
LOL !!
its complete :)
