Jean_quemener
Vacuum Pipe, Now Running Carbs?
Jean_quemener
Hi bit of a problem, im fitting an mi16 engine into my pug and im going to be running twin 45's. was just wondering what do to with the vacuum pipe that comes of the inlet mainfold on the 8v as this feeds to the brake master cylinder and was also told the sunroof as well. if i was to blank this would it effect my braking and stop my sunroof from sealing propperly, if needed any way around it?
thanks jean.
Matt Holley
thanks jean.
You need to drill and tap a take off into the carb inlet manifold, you can get them from demon tweeks, merlins etc.
Jean_quemener
ah i see, thanks alot mate.
there would usually be a port on the manifold for that purpose, or at least I remember every 8 valve one I've seen having one :)
Jean_quemener
i havent even checked my carb mainfold yet, i shall check when i get home.
MrG
mine had a take off for the vacuum pipe.
Guest Ad205
you can re use the original brass take of from the 8v inlet manifold that sits on the side if you still have it & matches your vac pipe just tap your carb manifold & a little thread lock.
