pablo 0 Posted February 9, 2010 Any tips? need to get mine off in a hurry this evening and a bit scared of making a mess of it. Also I presume the rears come off like the fronts? Thanks Share this post Link to post Share on other sites
omega 82 Posted February 9, 2010 (edited) 1st tip dont rush!! i find it best to start at the bottom corner and just feel your way round Edited February 9, 2010 by omega Share this post Link to post Share on other sites
pablo 0 Posted February 9, 2010 do they just pop out then? or is some jigglyry pokery needed? Share this post Link to post Share on other sites
WooDooUK 1 Posted February 9, 2010 (edited) your first step is to remove the red insert. if you look close at the stripe you will see the clips behind it. Use a small screw driver to slide these clips either forwards or back off the studs in the door. Once that is removed the actual door trim itself should slide down, do it carefully though as the lower behind the trim are no longer available clips are no longer available. Edited February 9, 2010 by WooDooUK Share this post Link to post Share on other sites
jimistdt 1 Posted February 9, 2010 your first step is to remove the red insert. if you look close at the stripe you will see the clips behind it. Use a small screw driver to slide these clips either forwards or back off the studs in the door.Once that is removed the actual door trim itself should slide down, do it carefully though as the lower behind the trim are no longer available clips are no longer available. ^Spot on. Share this post Link to post Share on other sites
pablo 0 Posted February 9, 2010 thats them off cheers lads just the arches to get off now! Share this post Link to post Share on other sites
Baz 421 Posted February 9, 2010 thats them off cheers lads just the arches to get off now! Arches are the same for the straight bits basically, then on pop-through trim clips for the rest, some have star-fangled washer things behind too though. Share this post Link to post Share on other sites
harryskid 193 Posted February 9, 2010 your first step is to remove the red insert. if you look close at the stripe you will see the clips behind it. Use a small screw driver to slide these clips either forwards or back off the studs in the door.Once that is removed the actual door trim itself should slide down, do it carefully though as the lower behind the trim are no longer available clips are no longer available. O yer i discovered that! Harryskid Share this post Link to post Share on other sites
