djinuk
106 Quicksilver Engine Problems, Please Please Help
djinuk
ok, car is a 106 quicksilver.
problem its always had is at random intervals the engine will have a bad missfire for about 2 mins and kangaroo. (this only happens once every 4 weeks or so)
next problem is that occasionly all revs will dissapear even though you still have foot on the gas (this often happens mid round about) and then all of a sudden it will kick into life)
between gears sometimes u feel a missfire before it pulls, similar to a carb when its playing up.
the car also doesnt feel smooth, and also when left idling will devlop a strange idle beat and eventually cut out, however once restarted this is fine again.
I put the problem down to a sensor.
so far ive changed the coilpack,
icv valve
map sensor
tps
ecu temp
all thats left is lamda
flywheel sensor
ecu
wiring loom
blocked cat maybe ?
really running out of ideas, its the girlfriends car so i really need to work it out.
Edited by djinuk
wracing
blocked fuel pickup/filter, or a very low fuel? :lol: or electrical connection!
james
Edited by wracing
djinuk
james
hmm, you know what , ive not even thought about the fuel filter, thats a bit fukin stupid of me aint it... !!!
i think it sits under the car on these, that should of been one of my first port of calls, fukin d*ck.. hmm still not sure if that would explain the idle.
