hillbilly 3 Posted February 1, 2010 Can anyone help can i use 306 gti6 front hubs on a 1.9 205 gti Share this post Link to post Share on other sites
Daviewonder 533 3 Cars Posted February 1, 2010 Afaik I think theres a couple of things to watch out for though like you will have less camber than with the 205 ones and there are two different wishbone ball joint sizes on the 306 so you have to make sure you get the right ones. Share this post Link to post Share on other sites
pug_ham 243 3 Cars Posted February 1, 2010 Moved to the correct section. Please try a search as this has been covered before quite recently. Graham. Share this post Link to post Share on other sites
yippeekayay 18 1 Cars Posted February 1, 2010 is it the smaller or larger 306 hubs that fit then???? Share this post Link to post Share on other sites
Daviewonder 533 3 Cars Posted February 1, 2010 I cant remember off hand but its on here somewhere, just search. Share this post Link to post Share on other sites
Alastairh 47 Posted February 1, 2010 The earlier 306 / xsara hubs are 16mm ball joints (the ones you want). The later are 18mm which won't fit. Al Share this post Link to post Share on other sites
yippeekayay 18 1 Cars Posted February 1, 2010 so you can use complete 306 gti6,front struts hubs, discs and pads and bottom arms, what driveshafts work in this combination??? Share this post Link to post Share on other sites
foreigner 0 Posted February 1, 2010 (edited) as I asked so many times before and I found out from good helpers here. They fit up to 98, they give positive camber, driveshafts are too long (however I once asked if BX shafts would fit with 309 bones - nobody answered that one), arms don't fit, I think that's it. So basically not worth if you don't mind expensive machining to create right camber or use 309 bones or as I tried to find out some custom made (found them £280 pair). Edited February 1, 2010 by foreigner Share this post Link to post Share on other sites
welshpug 1,645 Posted February 1, 2010 Andy, you have to use 205/309 top mounts and the thinner droplinks, but apart from that the dampers and hubs will go on with 1.9 205 shafts, or 309 shafts if you are using 309 arms, or indeed a 309 shell as I asked so many times before and I found out from good helpers here. They fit up to 98, they give positive camber, driveshafts are too long (however I once asked if BX shafts would fit with 309 bones - nobody answered that one), I think that's it. yep quite right, and to answer the bold bit... n/s compressed length = 592 mm splines on inner joint = 24 splines on outer joint = 25 o/s compressed length = 865 mm splines on inner joint = 24 splines on outer joint = 25 which is 25mm longer each side than a 1.9 205 shaft, so too long but will fit both hub and gearbox fine. Share this post Link to post Share on other sites
yippeekayay 18 1 Cars Posted February 1, 2010 thanks welsh pug, when we gonna meet Adam b was tellign me you arer a good lad... got this head in the unit off the s16 i could do with yr opinion on and cams so if your about sometime and wanna come over for coffee and dredge through my horde of stuff feel free... Share this post Link to post Share on other sites
